I have just downloaded mp4 to mp3 converter to extract audio from video files, but it is not working... I choose the file, then press OK, but nothing happens... what may the problem be about?
To be honest, there are a plenty of MP4 to MP3 converters currently. But, what is the most proper to you? If you are searching for the best way to convert MP4 to MP3 with ease, here, referring to the best MP4 TO MP3 converters would help you out.
Source 3 Ways to Convert MP4 to MP3 on Mac with High Quality
Cisdem Video Converter for Mac is one of the best video converter which helps users convert MP4 to MP3 safely and easily. Apart from its powerful converting functions, it also allows you to download Youtube videos and songs, edit videos, rip DVDs, even upload videos to Youtube within the program.
1. Upload MP4 files into the program
2. Choose MP3 as output format
3. Start converting MP4 to MP3 on mac
Are you sure you are doing everything correctly? Maybe you have forgotten to choose the destination path... this or that way, it sounds weird, it is most likely the problem with the converter itself. I recommend everyone this free mp4 to mp3 converter, I have enough experience with it myself, hope it helps you!
SOURCE: ikasu mp4 touchscreen
i had the same problem but i had a read of the manual and there should be avi converter with the mp4 player in the form of a mini disk you have to make sure it is at the right resolution i think mine is 320*240 and if it is not the right resolution it will just keep coming up with file error, just make sure the resolution on the avi converter matches the resolution on the mp4 player
SOURCE: How to delete write protected MP4 files
for delete .mp4 file i do this :
1) i install EasyDelete and i delete the file(when you select the file type put ALL FILE then select the .mp4 file )(The deleted file will appear with a X and will not disappear from the folder )
2) I reboot my computer in safe mod and i delete those file (with X mark ) using Del button.
3)reboot computer and empty Recycle bin
for me it work ,i delete in this mod some video file .
I use win 7
SOURCE: Video converter program not working in Visual Land MP3 player
you change this one, if can't, please send email.
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
