Feel the doors at handle height where they meet when closed. If it's noticeably warm on that thin spot it's time to 1st unplug the unit, 2nd remove the grill by the floor and 3rd carefully vacuum the underside. Don't be rough about it. The cooling pipes and fan base can be fragile and easily damaged...resulting in the purchase of a new fridge.
Its either the sensor or the main board: https://www.repairclinic.com/Shop-For-Parts/a4b3d852471/Model-GSL25JFTABS-GE-Refrigerator-Parts
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
