Sharp AR-5316 Advanced Digital Imager Copier Logo
Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In sharp 5316-toner is not transferring from toner cartridge to developer unit , copy is light .
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on May 31, 2012
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1109644
Points
5835
Most likely need to replace the developer
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Jan 02, 2008
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Anonymous
  • Posted on Nov 10, 2008
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Anonymous
  • 146 Answers
  • Posted on Jan 06, 2008
SOURCE: sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Anonymous
  • 6 Answers
  • Posted on Feb 19, 2009
SOURCE: refill of toner on sharp 5316
i dont advice for use refill toner but if you want to do so you can take the litlle white cover on the end of the cartidge and refill it
Anthony Karuku
  • 268 Answers
  • Posted on Dec 01, 2009
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
1helpful
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
1helpful
2answers
Sharp ar 5127 erorr u 2-40
Pl do something as follows (1) Change Toner IC Chip (90%), (2) Check the toner Cartridge. If it wont be done, pl let me know.
Shawn.
3answers
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
2helpful
2answers
Sharp al 2040 cs copy comes out blank
Check the drum or developer unit whether they are rotating and make sure there is developer installed. Then clean the main charge unit and check transfer corona wire if dirty or broken and replace.
13helpful
4answers
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
2helpful
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
COPIERS - AR-5316
The developer unit is inside the cartridge where the toner sits in. usually if you remove the toner hopper out of the copier and remove the top cover off you will see one compartment with toner and one with developer in it. The carrier is the the type of developer to use. All old developer needs to be removed from the machine as well as the mag roller in order to replace it.
Once it is removed the developer is placed evenly into the comparment. The hopper is reinstalled. Then a service mode is performed to calibrate the developed to make sure that the mixture is equal with the toner.
It should be done by a technician because if it isn't done properly, it will result in light copies being produced. The developer may get contaminated and have to be replace if it isn't done in the proper order.
2answers
Sharp AR-5316 will not print
check the toner. it still have a tape covering the opening . look for a yelow or red tab at the either side of the cartidge.
good luck
if this answer your problem, please rate it
Sharp COPIERS - AR-5316
The cleaning blade is in the drum cartridge.
There is no developrer change in that product.
There are 2 cartridges.
The toner and drum.
Toner contains all you need as far as ink. And also the waste sump is on the toner cartridge.
The Drum is a self containted unit that has the cleaning blade and auger built in.
5helpful
7answers
Sharp copier ar-5316
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
