The lights will not turn off with the remote. The bulbs have to be unscrewed. Batteries were changed in remote, and fan works with the remote. Kichler Model 35005 type H
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
SOURCE: remote control
i bought two hampton bay fans and 2 remotes...the electrician installed both and bothe remotes control both fans and lights...so im in the living room turning on the light and it also turns on the bedroom light....can i fix this?
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area
of the fan that the globe screws into. I wore rubber dish gloves to get
a good grip and pushed up slightly on the globe as I turned
counter-clockwise. My friend held the other part and turned clockwise a
little as well. It took a lot of pressure for it to finally come loose
and then we just turned it about another 90 degrees and the globe slips
right out of the groove.
I couldn't believe how hard this was to do.
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
press up while turing it counter!
SOURCE: I have a Futura Model
While holding the fan blades turn the light cover anti clock wise. That is turn the cover in the direction of the fan rotation.Make sure somebody helps you by holding the blades to prevent the top part of the fan from rotating while you attempt to remove the glass cover.
