Frigidaire FEF336BC Electric Kitchen Range Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire Smooth Top Range/Oven stopped working
My Frigidaire range/oven had been working perfectly when suddenly the oven would no longer heat up. The display still comes on and operates normally but the oven won't heat up. A few weeks later the range elements stopped heating up as well. What should I check first? the bake worked yesterday but not today. Broiler works but cannot bake anything. Electric panel is working like normal but the bake does not heat up..
  • 7 more comments
  • pissedof2008 Nov 27, 2008
    My Frigidaire range/oven had been working perfectly when suddenly the oven would no longer heat up. The display still comes on and operates normally but the oven won't heaT What should I check first? the bake worked yesterday but not today. Broiler works but cannot bake anything. Electric panel is working like normal but the bake does not heat up..
  • disappointd1 Nov 27, 2008
    The same thing happened to me today. I used the oven in the morning but, a few hours later, nothing. And the oven is not that old. I know of other manufacturers' products that last 5 times longer than this. I guess I should expect the rest of the stove to go any day.
  • jcbagnal Dec 08, 2008
    Same here. All functions work with the exception of the baking element. replaced the push button panel assembly 100 $ down the tubes, it did not fix the problem. WTF!
  • Anonymous Dec 21, 2008
    I had the same thing..used it yesterday and now it won't heat up. Stove burners are still working though (not sure how much longer)
  • speedsmill Jan 11, 2009
  • Anonymous Feb 12, 2009
    I used my over a couple hours ago and now I went to heat it up again and....nothing.  Top works, clock works, but oven won't heat up!!  WTF!!!
  • Lily_Kay Mar 04, 2009
    Have the same problem, the oven was working find and all of a sudden it stopped and would not heat up. Turns on and off and you hear the engage/click when you turn it on. I decided to look at and test the voltage, when I took the casing off the get access I hit the bake botton to turn on and "boom" I tripped the main breaker, lights out. So once I reset the display doesn't work at all, obviously the timer is fired but I am not sure why this would of happen, it must of shorted on something but still doesn't make sense. Any suggestions on where to get a get price on a timer? Located in Canada, Ontario
  • Anonymous Nov 03, 2012
    Our oven won't heat until we turn the timer on. I don't know why, but then it works great.
  • Anonymous Mar 15, 2014
    Whirlpool accu bake part 9756207
daveyates
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 112 Answers
  • Posted on Dec 28, 2008
daveyates
Expert
Level 2:
Cheetah:
Answers
112
Questions
Helped
31456
Points
174
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7560
Points
You need to buy part number 316207620N which is the clock. They cost approximately $277.00. I don't suggest buying the part from Sears though because if it doesn't work, they won't take it back! I found that out today.
If you decide to buy from them and It doesn't work and want to take it back, don't tell them you installed it.
5 Related Answers
fixyourboard
Fix Your Board
  • 310 Answers
  • Posted on Feb 21, 2010
SOURCE: Broiler will not work. Broiler Switch indicator
Three possibilities:
1. Bad Broil element.
2. Wiring problem to broil element.
3. Electronic controller failure (this can be repaired).
Anonymous
  • 1543 Answers
  • Posted on Nov 08, 2008
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 25, 2009
SOURCE: Kitchenaid electric convection range - preheats
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 43501 Answers
  • Posted on May 14, 2010
SOURCE: Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
4helpful
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Display not working nor oven frigidaire gallery smooth top
Could be a thermal cutout or control board problem. If you can email me the exact model number at [email protected] I may be able to help you troubleshoot the cause.
Regards,
Bruce
www.fixyourboard.com
Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
2answers
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
2helpful
5answers
for all others with this problem: I had the stove serviced. Repairman reported a loose wire to the elemets (tightened and did not fix the problem) followed by a stuck relay, and after some banging on the back of the control panel, the elements now work fine. He said if it happened again the only solution would be to replace the relay/control panel, a part of about $160, but I'll get credit for the price of the service call already paid. Compare to the price of the stove, I'll accept the $125 for the service call.
so tapping on the back of the control panel is worth a try if your stove is pulling this trick.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
