Ive checked all the fuses , and as far as i know all of the relays
SOURCE: mdx rear air fan not
maybe the fan itself is the problem, it could be a carbon brush problem,,,try to tp the motor while it is on, if it runs, then the brushes are short already...
i hope i was able to help
tnx,
drcool
pls rate me
SOURCE: Acura MDX A/C won't come on
I went to an Acura dealer to buy the transistor for the rear A/C unit. The service advisor told me that the problem with the front A/C was probably due to a defective front transistor / resistor. I bought that part too.
The front transistor is located next to the blower motor under the dash on the passenger's side. It is secured by three or four small bolts. The one on the bottom left is very close to the carpet and the most difficult to get off and put back on.
The rear transistor is located behind the carpeted trim panel on the center console (driver's side). The carpeted trim panel is secured by clips only - there are no screws, so remove it carefully starting at the side near the accellerator pedal. Once the panel has been removed, reach inside a small hole in the metal frame to access the rear transistor. It is removed by twisting it and pulling it out. The hole in the frame is small and you might find pliers helpful.
After replacing both parts, the front and rear A/C are working. Apparently these transistors are common failures. If the A/C is out in your Acura MDX and the fuse checks good, a new transistor will likely solve your problem.
SOURCE: 2006 Acura MDX bluetooth stopped
Bluetooths have batteries, Rechargeable. If it won't hold a charge replace the batt.
SOURCE: 2001 Acura MDX Stalling.
you may want to check the ground wire for the engine; if the car just shut down it's possibly an electrical. if the ends are corroded replace.
SOURCE: Need to reset the code my Acura MDX navigation
check the side of the glove box. my TL has it on the outside side panel as you look from the driver side. my honda prelude had the code there as well. hope this helps
