Kindly help me for Acer aspire 4520, Which driver need download.
SOURCE: Where to find Acer Aspire 4715z driver for Windows 7?
Acer aspire 4715z does support Microsoft windows 7 but Acer doesn't release any driver till date. so, it's almost impossible to get the driver for windows 7.
but there's a way to work out.
just download the driver for windows vista using the link below
http://www.acer.com.au/acer/service.do;jsessionid=4CABD6FF9BC3961EF92EA7451A95FC04.public_a_14c?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
Follow this step
Select Product Family : Notebook
Select Product Line : Aspire
Select Product Model : Aspire 4715z
All the driver will be listed below, by default the driver listed is for microsoft windows vista Home premium.
Download all the drivers that you need.
Now, install those driver meant for windows Vista in windows 7, Most of them or all of them will work as 90% of the driver meant for windows vista works fine with windows 7.
Now, make sure you have internet access through a LAN or wireless network.
Download "Driver genius pro" using the link below
http://rapidshare.com/files/270454654/Driver.Genius.Pro.9.0.0.180_by.tano1221.rar.html
Install the software and let it update.
This software has a huge database of drivers and I'm very sure you will get the latest drivers for the operating system i.e windows 7 in your case from the chipset manufacturer sites directly through this software.
It will most probably solve the drivers problem.
Testimonial: "Great! Thanks..."
SOURCE: cd-rom icon missing from My Computer
This will put it where it was, Thank You
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I need windows 7 driver to 7 Acer aspire 9500
Now there's an Update from Windows Update, it's listed in the optional Updates
SOURCE: i need a link to download acer aspire 1692 windows
go to http://tim.id.au/laptops he may have what your looking for on download
SOURCE: Aspire 4520- Windows 7: Webcam does not work properly
windows 7 has a compatibility program built in for addressing those issues from the previous operating system(XP)
go to start and in the search window
type in compatibility
this program will help you by running the program to test its functionality,
it will bring up a list of programs and ask you to select the program your having issues with,
then it will give your operating systems and service packs to test against,
at the end it will ask you if you want to save these settings.Y/N?
If the program runs ok then save the settings and it should continue to work from there.
Shut down and restart should embed these settings ,
Test again for function,
If no luck run the program again
You say that your system is dual booting,why?
windows 7 leaves XP for dust,
remove xp its taking up valuable space on your hard drive and possibly interfering with your systems operations,
Normally the hard drive will only allow one operating system on it,even if you have partions.
Fine tuning is all your looking for so let us know your outcome thanks
If you do a windows back up
which system is it going to back up?
normally it will write over the last backup you made and the new one replaces it,
Cheers MISTERDJ
