A chime goes off every hour but not on the hour exactly there is an image of an hour glass. How do I turn this off. thank you.
SOURCE: dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
SOURCE: i want to know how
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
SOURCE: hourly chime
You can get instructions from the Timex web site "timex.com".
At
the bottom of the screen click on "manuals/downloads", then on "product
manual
download"
Enter your watch type in the search box and click on
"search"
SOURCE: can't turn off chime on timex ironman watch
Go to the timex website, scroll to bottom, click on Product Manuals and Downloads. Then at the bottom of next page, find your watch by model number and look up how to control chime in instructions. It is usually something in the alarm menu... in my case, hitting stop/reset in alarm mode toggles the chimes.
http://assets.timex.com/user_guides/W9_M814/W9_M814_AllLanguages.pdf
