My electtrolux washing machine is new
SOURCE: Error E145
the ecb ( electronic control board ) has detected a malfunction.
check all wiring to the ecb and replace if needed.
also try unplugging the machine for no less than 5 minutes to clear all codes to see if the problem is intermitent or not, hope this helps....
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
SOURCE: HiI Hve an Electrolux W4139N washing machine that
That model does not exist on our system and Error code 27 does not exist either.If you can find the product number inside the door then we may be able to help you,just re enter your query on the system..
Hope this helps.
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
