1995 GMC Suburban Logo
Posted on May 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 1995 suburban won't go faster than 25-30 mph even with foot to floor,service engine light on
Car was driving fine then when I got on freeway car won't going faster than 25 mph
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1258
Points
Im having the same problem did you ever find the solution , i was driving on the high way and it just stopped going fast and was hard to get it to go past 30 mph
  • montehammons Dec 02, 2012
    Vanessa, first thing to do is have the computer scanned for trouble codes. Codes need to be addressed first, but if no codes were set, then have the fuel pressure tested. A pressure test will tell you if the fuel system is at fault.
montehammons
Level 3:
  • GMC Master 5,531 Answers
  • Posted on May 30, 2012
montehammons
GMC Master
Level 3:
Answers
5531
Questions
Helped
1642315
Points
17401
Foot to the floor, go directly to a parts store, and get a free scan of the computer for the trouble codes and their description. Post them here, or have a mechanic start diagnosing what the codes tell him to check.
Good luck.
5 Related Answers
Anonymous
  • 112 Answers
  • Posted on Apr 02, 2009
SOURCE: car began to lose power while on freeway then stopped
Sounds like the alternator is going bad and killing the battery.
Anonymous
  • 243 Answers
  • Posted on Apr 19, 2009
SOURCE: Service Engine Soon Light
The best way to know what is happening there is to drive a GMC dealer and get them to hook in the diagnostic tool and read the computer memory for present faults.
Cheers
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Nov 15, 2009
SOURCE: 1995 k2500 suburban idle too fast
replace the coolant temp sensor,it`s values are off,it is defective.Also if this does not work,witch I think It will,change the throttle position sensor.
Anonymous
  • Posted on Nov 22, 2009
SOURCE: my 1995 gmc suburbans service engine soon light
have a 1995 gmc suburban new fuel pump new relay the truck fired up after fix. put 30 gals of fuel in tank . never ran so good started up next day put about 20 miles stopped for 15 min and no start pump does not run at this time . put fuel in intake will run as long as you do this.towed home let sit for 1 hr and turned key on pump runs truck fired right up .ran 100 miles did same thing is running now but dont want to go to far from home please help
Anonymous
  • 7353 Answers
  • Posted on Nov 30, 2010
SOURCE: 1995 2.2 GMC Sonoma service engine soon light
First, you need to have it scanned for codes, then you will know what to look for. Dont replace anymore unneeded parts until you get a trouble code. you will need a OBD1 scanner. You will only know the cost and cause when you find the problem.
Engine dyed while running on the freeway.
Any error code?
Check fuel and ignition system
1helpful
Engine won't go over 5-10 MPH
You need to take the car to the dealer, because you need to recalibrate the electric throttle body with a TECH 2 Scanner, because the system went into a Limp mode.
My 97 Saturn SL2 won't go past 30 mph. Even with
I guess my first question would be - are you saying it is slipping in 3rd gear ? If you push the gas pedal to the floor it should downshift into a lower gear.
If it is slipping, or not upshifting into 3rd gear, I'm afraid chances are the transmission is toast.
You can take it to a couple of shops for estimates but they will probably want to pull the pan and take a look inside.
My 93 Suburban 5.7L takes off too slow and hard to get it over 60 mph on the freeway
Have you replaced your air filter or checked you mass air sensor for debris or contamination?
My ac quit working (won't even blow), windows won't go up or down and radio wont work only will eject
Hi Kolya, Check around for a loose or broken cable especially around the battery connections. Regards John
I have a 93 j30 that drive fine but won't go into
check the gear linkages on the gearbox and none of the floor to see if something has jammed the mechanism.If not I would suggest that you get somebody to inspect the gearbox.Regards
Hi ! already bough 2001 gls jetta whit 79000 miles and the EPC light comes on and off I drove the car on a hill and the freeway and the car ran faster but the light come on and then goes off, today i was...
I wouldn't trust changing the MAF sensor out first. The make a cleaner that you can spray to clean the MAF. If this gets a little dirt on it, the air flow will be scattered causing the vehicle to ****, shut off, not start, etc. These are very sensitive and it REALLY don't take but your hand about 1 foot away from the air flow of this sensor, and your engine shuts down. Clean it first then go to option B...
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
