Hi Riger, Can you provide some more detail about your problem? As a first
step you should have your system scanned and find out what is triggering
the emission light. It's unlikely that the thermostat will trigger an
emission issue, unless it's the thermostat in the catalytic converter.
Since it only does it when ya let off the throttle,with car stopped and raised enough you can reach the drive shaft with emergency brake on and shift in neutral,grab the drive shaft and twist it back and forth to check if too much backlash in rear pinion and ring gear.If too much backlash,pull the drive shaft off the rear and tighten the nut JUST enough to take the backlash out near completely.Riger says,don't let the car roll while doing this.Block all wheels.
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
Satellite phones in general will have a lower battery life, and it is
not always easy to make and maintain a connection. The antenna of your
phone should always be pointed to the direction you think the satellite
is (you should check this before hand). You will have this will
satellite phones, the Hughes 7101 is no exception. Did this in any way answer your question?
you need to open your cell phone. clean the riger contacts if not then check the ringer buzzer if it is ok, check it with a multi tester. and lastly make this jumpering
