Question about Kaz Honeywell Tower Air Purifier with IFD (HFD-120) Air Purifier
Honeywell Air Purifier - HFD - 120 won't turn on after cleaning.
I cleaned the air filter as the manual instructed, and put everything back together. I reset the red light. Now my unit will not turn on at all. This was the first time I cleaned it since I got it.
    Master:
  • 407 Answers
Check connection ware.
Posted on May 30, 2012
SOURCE:
SOURCE: Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
Posted on Dec 20, 2008
  • 14 Answers
SOURCE: reset filter
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
Posted on Dec 02, 2007
SOURCE: Honeywell HFD-135 -- lost instructions -- how do i clean removable filter?
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
Posted on Dec 08, 2008
SOURCE: We have HFD135 air purifier
i need infomation how to operate
Posted on Jan 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: I had a honeywell hepa
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Posted on Apr 13, 2011
Putting filter back in a Honeywell air purifier model hfd-135
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Honeywell QuietClean HFD 110 Series User Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 22, 2016 | Honeywell Air Purifiers
New Honeywell hfd-120 purifier will not turn on.
If it is new enough it could be due for a warranty replacement. Otherwise, there could be an open fuse or a failed switch.
Nov 29, 2014 | Honeywell HFD-120 Air Purifier
Where can I get the manual for honeywell hfd 130 air purifier?
Please refer to the link below for the Honeywell HFD-130 online manual:
Honeywell HFD 130 Owners Manual
Ava B.
Feb 28, 2010 | Honeywell HFD-130 Air Purifier
Lost the manual on my Honeywell HFD 110
Found the manual - take my question off this site.
Dec 04, 2008 | Honeywell QuietClean HFD-110 Air Purifier
Sep 10, 2008 | Kaz Honeywell QuietClean HFD-135 Air...
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Reset filter
May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
Air Purifiers Logo
2,445 people viewed this question
Top Kaz Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
