In large house have one base uniden dect2080 with four phones, but house is too large for base station to reach remote phones. Was told I can purchase a second base and attach it to the same number and use that base in the other part of the house. Will this work?
Products are:
- Uniden Dect2080 Series w/ 4 handsets
- Uniden Dect2088 w/ 2 handsets
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
SOURCE: need uniden DECT2080 user manual
hello.
You can download manual from here
http://www.uniden.com/pdf/DECT2080om.pdf
gud luck
Testimonial: "Great, thank you so much, downloaded it already!!!"
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
SOURCE: lost manuel uniden DECT2080, how
You can download the manual from the manufacturer's web site at
SOURCE: Need a user manual for Uniden DECT2080. I have the
You can get the manual on the link below.
http://www.uniden.com/pdf/DECT2080-2om.pdf
Good Luck and please rate 4 thumbs up for the free answer
