Televison & Video Logo
Anonymous Posted on May 30, 2012
My sony tv the look in black,but has audio, what is the problem?
The tv look in black, but has audio, can you help me in this trouble. thank .aramos88..........
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on May 30, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006400
Points
237762
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
Look for the fault post 'No Picture Sound OK'
Sony bravia kdl 50w800c 3 times red light blinking error
Either the Standby voltage is missing or the main board is defective.
Sony tv black screen
Repairing a TV set is actually a skilled work. If you're not sound in electronics, make sure, that you can't do it; especially to Sony sets. If the set switches ON; with audio output OK, and there is no Video, surely the fault should be with its horizontal scan output section circuit. Check that circuit for fault. To get more details, http://electronicshelponline.blogspot.com/
Ps3 goes to black screen then to normal
It could be as simple as your video cable going bad. Check to make sure the wire is in good shape and that the contacts and connections are secure.
I would say try using it with an HDMI cable (if possible) and see if the problem persists. You can also try and hook up another device (DVD player, camera, PS2, etc) to the TV input you are using now and see if it is the TV that is giving you trouble.
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
No sound from new sony bravia to denon avr 1610
TV's are not your best source of audio. Get the TV-related audio digitally from the source, NOT the TV.
7helpful
Sony trinitron xbr screen periodically goes black. The audio stays on but the video cuts out.
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
3helpful
PS2 screen won't show on tv set to game
try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
