Normally the charge will last for a couple weeks or so. Unfortunately, just as the last week, the charge is only lasting a couple days. Is there some sort of reset for the headset or something else I can do?Normally the charge will last for a couple weeks or so. Unfortunately, just as the last week, the charge is only lasting a couple days. Is there some sort of reset for the headset or something else I can do?
You can't post conmments that contain an email address.
If it is less than a year old contact Motorola Support (http://www.motorola.com/support) if it is longer than a year old you may need to get a new headset if you have already tried another charger to ensure it is charging properly.
I have a motorola H730 and it just died and will not charge... no lights come on to show the degree of charging. it is only 3 Months old. Can you provide an answer why this is happening.
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
I think I am having the same issue: When you open the H730 up do you hear beeping noise instead of a womens voice. Also does it stay on until you open it for a second time.
First thing to do is make sure Bluetooth is on for BOTH devices . Second thing is to make Both devices Visible. Third is to Scan for nearby devices. You will need to know the 'device name' of each phone. When you find the other phone on one device, click on it & it should ask you to 'Pair device'. You should then hear an 'alarm' tone & get a message in a box. (sometimes you need to 'pull-down' this message from the top of the screen, like you do to get the settings or wi-fi status). It will ask you if you want to pair & then give you a 'Pairing code'. This is what you type into the phone. The other phone will then get this & ask if you want to pair. Say yes & the two phones are paired ONE WAY. You need to repeat the process for the phones the other way around, so that the phones are paired in both directions. Remember, every time you get the 'alarm' tone, to check your 'pull-down' to see if the connection code is hidden up there.! Telling it to you is more complicated than actually doing it.!!! Best of luck.
