The Dish remote only has about 60 possible codes built into it--try to Google the model number of that remote to locate (also can ask Dish) a manual with possible codes.
You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds. - Press 9, 8, 7, 6 and ENTER in the sequence. You should be in the installer menu now. There should be a line that looks something like this: 03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off) START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
