Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop Logo
Posted on Nov 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why are all of my ignoiters are clicking in the off position?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 311 Answers
  • Posted on Nov 29, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
311
Questions
0
Helped
81531
Points
758
Spark module is bad or a switch is stuck closed. You can check this by removing a wire from each switch to see if it stops. Need to take c/t apart. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Have a gas cooktop that clicks even when the knobs in are in the off position
Good Afternoon Hon,
I understand that your Frigidaire gas cooktop, model# FGC30S4ASA, is clicking even when the knobs are in the off position. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and listen for the clicking with the burner knobs in the off position. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
1helpful
2answers
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 • GE Cooktops
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
The gas knobs are in the off position but the auto start is click
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
2answers
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 • Cooktops
1helpful
Continual clicking of the automatic ignitor even when burners are off
some JA models i have seen the the spark switces are poorly constructed or improper installed from the factory and beging to become a probelm after a year or so of use. this is not a gas pressure issue it just plain ole' bad spark switches
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
