Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
Problem with Panasonic RR-830 Desktop Cassette Transcriber / Recorder How do I fix the belt that turns the cassette? I checked the pause button and it is off. So it has to be the belt or the motor
4 Suggested Answers
SOURCE:
  • 145 Answers
SOURCE: Panasonic RR-830 only rewinds and fast-forwards, will not play
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Posted on Nov 08, 2008
  • 67 Answers
SOURCE: My Panasonic RR-830 turns on, but the cassette
Most likely the internal belt has broken.
Posted on Jun 30, 2009
  • 11 Answers
SOURCE: How do I download voice recordings from my
The RRUS551should come with a short USB cable that you can plug into your PC at one end and the RRUS551 at the other. Windows should detect your device automatically and present you with a menu of choices.You can select "Open containing folder and view files."
This will open an Explorer type window where you can just select the files you want and copy and paste them to somewhere else on your PC.
It is better to shut down your PC completely before disconnecting the cable.
Else you may corrupt files on your device.
Hope this helps.
Posted on Sep 14, 2011
My transcriber has started turning itself off.
Hello your unit needs service and is probably need to replace internal power switch you may take advantage of after Christmas 50% Off Service Rates Special it is only from Monday Dec. 26th thru Friday Dec. 30th 2011 only. At http://www.tvps.com/Products/One-Service-Unit-for-AnalogDigital-DesktopPortable-DictationTranscription-Machine__ECS-ADDPS.aspx
Dec 22, 2011 | Panasonic RR-830 Desktop Cassette...
Machine will play cassettes but not rewind or ff
Most likely the unit needs new belts. Also possible that a switch has broken. the switched is underthe tape deck on the circuit board.
May 06, 2011 | Panasonic RR-830 Desktop Cassette...
Power button does not stay on
Likely problem could be a faulty pause lock switch
Sep 29, 2010 | Panasonic RR-830 Desktop Cassette...
I cannot press the record button down and the power button just does not stay on.
The buttons on this machine are gated with a mechanical mechanism (under the buttons in the machine -= you can't see it) that acts as a "gate" to control how the buttons behave. This mechanism is probably stuck and needs to be looked at by someone with mechanical inclination - short of calling customer service for service locations. It shouldn't be that expensive to fix. Good luck.
Apr 20, 2010 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-830
The headset you are using is a stereo headset. This unit uses a mono headset. Look at the end of the headset. If there is 2 black rings, it is stereo. You can get a stereo to mono adapter at Radio Shack for about $2.50.
Nov 13, 2008 | Panasonic RR-830 Desktop Cassette...
Spindles will not turn
There is a rubber drive belt that needs to be replaced, Panasonic part RDV101YA. This place says they have them:
http://www.partstore.com/Model/Matsushita/Panasonic/RR930.aspx?ModelAliasNumber=rr-930
I've never had to work on one of these so I can't say exactly what you might have to remove to get to the old belt and pulleys it rides on. But it's usually not too bad of a job to change a belt.
Nov 12, 2008 | Panasonic RR-930 Desktop Cassette...
Speaker problem
The headset jack is broken and needs to be replaced.
Nov 04, 2008 | Panasonic RR-830 Desktop Cassette...
Jul 30, 2008 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
43 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
