I have a Panasonic Lumix DMC-F3 digital camera. I recently brought a transcend 32gb sdhc memory card for it but every time I insert the memory card into the camera, this message appears "memory card full, insert sd card again". Do i need to format the card? if so, how do i do this?
Hi My Lumix FZ28 works with a SDHC 8GB but not with a Micro sd 32GB even if I formatted it to Fat32. By the way if your card does not work you do not have access to the settings menu of the camera so you cannot format in the camera !!!!
SOURCE: Got the dmc-ts1 couple of weeks ago, can't read SDHC cards
The card needs to be formatted in the camera to work properly.
SOURCE: sandisk sdhc 4gb memory card wont work with my
You need to format the card in the camera to optimize it.
SOURCE: I have a Panasonic Lumix
Hi I think it may be because the recommended size card is about 1/2 gb and check out your amnual or go to a web site which allows the downloading the manual
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
SOURCE: My Lumix DMC ZS7 reads
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Thanks chris, i tried that but when the memory card is inside the camera, i screen turns completely white and the message won't disappear unless i turn off the camera and take out the memory card. As a result, i am unable to access the format or any other settings when this message appears with the memory card in it. Do you have any other suggestions?
