On my Lanier VW 210 transcriber, you can be listening to a tape and then all of the sudden it will beep like it is at the end of the tape. It is also starting to do this even while rewinding a tape. In order to continue using, you have to open the cassete door and then shut it back again. It is happening more and more frequent and making it hard to listen to tapes. Has anyone else had this problem?
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
