Olympia CDP 24201 Cordless Phone Logo
Charise Reeves Posted on Jan 09, 2007
No dial tone on handsets
I have an Olympia 2.4 GHz Digital Spread Spectrum 2 Line Cordless Phone model # CDP 24201. Our setup includes the base unit that holds one phone and a separate speaker phone and two additional handheld phones. Recently we have experienced where we can get a dial tone on the base speakerphone, but not on any of the hand held units. You press the button to get a dial tone and it does absolutely nothing. I have tried to reregister the phones, but they either get stuck on the scanning portion or finally come up with EMPTY. Any suggestions on what to do? I have unplugged the phone line, turned off the power, unplugged the power line from the back of the base unit... This happened before and after repeatedly turning the power off, we got a dial tone. This doesn't seem to be working this time.
  • Anonymous Mar 30, 2014
    The phone seems to do everything else - call display works, rings when a call comes in, date, time, tells you who's call, but when you turn it on, there is nothing when you listen - no dial tone, nothing, and the speaker phone doesn't work. it seemed to have started with first the head set not working, but I could still use the phone. Then I was using the speaker phone and that just stopped working too. I've taken out the batteries, unplugged it, changed bases with the main phone.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 07, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1137
Points
Hey.. Did you check to see if the phone is registered correctly ???
  • Anonymous Jun 07, 2007
    You may want to reset the base and re-register your phones... I had the same problem.
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Mexican buyer
Pulse el botón verde, cuando se desea hacer una llamada telefónica pinchie embesi.... leer las instrucciones, en español, faboso
1helpful
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
My Olympia cdp 24201 has no sound i called it from my cell phone and no ring. i answered and could here myself talk on my cell phone but not on the olympia no sound at all
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
5helpful
2answers
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
4helpful
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
2answers
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
2helpful
5answers
Need maual for CDP 24201
http://www.amytel.net/download_file.asp?ID=D42807F02D7DA0E0 There you go.. That is the URL for the manual. LOOKING FOR THE SOFTWARE/Driver still !!!!
2answers
Olympia cdp 24201 cordless
need more info but thats a new model and most have warranty, have you benig used before or is the first time can you see some indication of be in charging mode..post back..
Top Olympia Lands Phones Experts
k24674
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
