Computers & Internet Logo
Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blocking URL's Using Wireless Router with Wireless Connectivity
I have a linksys wireless router wrt-120n model, both computers are in wireless connectivity. How can I be able to block URLs if I have a dynamic IP addresses?
Shawn DuRee
Level 3:
  • Master 356 Answers
  • Posted on May 30, 2012
Shawn DuRee
Master
Level 3:
Answers
356
Questions
Helped
131848
Points
1300
HERE. look on page 17 of the .PDF, it shows you how to block web addresses and other types of traffic. Its under chapter 2 Access Restrictions > Internet Access
2 Related Answers
Anonymous
  • 5 Answers
  • Posted on Mar 28, 2010
SOURCE: laptop cannot acquire ip address from router even
make sure your network card is active . for tcp/ip then try resetting all 3 devices router/modem and laptop. (same time) Good Luck.
Anonymous
  • 109 Answers
  • Posted on Jul 20, 2010
SOURCE: linksys wrt 120n connected but can't browse
Check your computer's browser settings, make sure it's getting valid IP address, try pinging a website and check your IP settings under network connections.
Disable any third party firewall software you have installed.
Hope this helps!
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
1helpful
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Linksys wrt 120n connected but can't browse
Hope this helps!
Hey guys could i use my router as a radio to pull the internet signal from a next router without using any cable
With the Linksys router it is not possible. You will need to connect the cable between the two routers. Linksys router will not pick up the wireless signal from the other wireless router.
May be it will work If you upgrade the DD-WRT Firmware. Not sure but it may. consult with the DD-WRT expert before upgrading the firmware.
Rage expander
Yes that should be possible to configure a range expander with your router.
You can follow the steps from this link on how to do that
http://www.fixya.com/support/r4073242-configuring_wre54g_wireless_router
Linksys WRT150N
There is always a wireless option on your router. Check to make sure that your wireless is turned on and that you arent blocking your wireless signal with a WPA personal passcode.
2answers
Internet connectivity problem
try to upgrade the latest firmware for the router and reset and reconfig it..
Grand Canyon Tech
Grand Canyon Tech
