E-Machines eMachines Desktop PC Logo
Anonymous Posted on May 28, 2012
Doesn't recognize me as the Administrator and no one uses it but me.
  • Anonymous May 31, 2012
    Your suggestion did not work..sorry
    one step at a time so where is this adminstrator not happening in the log in sequence do you get a log in screen?
Anonymous
Level 3:
  • Master 821 Answers
  • Posted on May 29, 2012
Anonymous
Master
Level 3:
Answers
821
Questions
0
Helped
159132
Points
2407
Ok well did you log out from user panel? try that then restart and should ask for main user log in screen
hope you have your password handy
I installed new printer cartridges - computer doesn't respond why?
Three possible causes -
- Your ink cartridge is fake or
- your computer set up requires you log on as administrator to install peripherals if it is a shared PC.
- You did not switch on your printer while your PC was booting to allow it recognize the printer set up.
Solutions:
If you can afford it, get another new ink cartridge from an authorised dealer and try again. Secondly, check whether there are administrator priviledges attached to installing new ink cartridges. You can view your profile setup from the Control Panel to confirm this
Finally, switch on your printer immediately you power on your PC so that the booting process can recognize your printer setting. Do check that the ink cartridge you are using is approved for your printer.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Cant upload to youtube its saying you need to modify the file or something along those lines.
TBH... that doesn't make sense.. UNLESS--perhaps.. Are you NOT an administrator (or have administrator access) on the PC your using?
Please let me know.
I'm doing a typical brake job on a 2002 Merc. Mountaineer
I do not have to use a scanner on my wifes lincoln ls & a
relative has a ford 150 & expedition and doesn't have all the
tools I have,so no,you should be okey
I would believe that the hcu would be open for the most part
when you drive & only actuate the valves when you get wheel
that is recognized from a wheel speed sensor
I have yet to have to use my scanner to answer your question
No that doesn't mean what you can do & what a factory service
manual says is the same
Your Dodge may have other issues from moisture in the system
or a failed component.
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Asus motherboard doesn't recognize western digital drive
clean your Socket - not use long cable - use co-oxual cable or" land line cable if use long - keep out ware any high frequency & high power line.
2answers
I have a ZX4931-31e gateway all-in-one. i did a system restore back to factory settings. when it rebooted i was asked to log in and i don't know what the reset administrator password is? i tried...
Have you tried a blank password for the administrator. Just press enter when administrator pops up. If that does not work, try administrator. That should solve your problem.
Thanks for using FixYa!
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
