Cameras Logo
Anonymous Posted on May 28, 2012
How do you date stamp panasonic lumix photo
How do I get the date stamp to appear on the photo when I transfer from my camera to my PC. I have a Panasonic Lumix
  • Anonymous May 30, 2012
    Still can not figure it out
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on May 28, 2012
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10425538
Points
622693
The date and time (and a lot more) are stored with every photo in its EXIF metadata. This data stays with the photo unless explicitly removed. Just about any photo viewing/editing program should be able to show you this data. If you want to print the date, please refer to the documentation for whatever program you're using. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
5 Related Answers
Anonymous
  • 172 Answers
  • Posted on Apr 07, 2008
SOURCE: Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
Anonymous
  • Posted on Dec 04, 2011
SOURCE: panasonic lumix Fz28, Error "Thumbnail is displayed"
What is the solution for this problem please. Thanks.
kakee
Michael Galve
  • 1269 Answers
  • Posted on Sep 16, 2008
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Anonymous
  • 155 Answers
  • Posted on Feb 09, 2009
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Anonymous
  • 1705 Answers
  • Posted on May 02, 2010
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
How do I date stamp my photos on a Lumix FZ70?
Your photos all have a date stamp as well as all the camera settings when shot and are revealed in your editing software. I don't know how to have the date printed on the face of the photo. You can download the 226 page manual at http://panasonic.ca/viewing/ALL/DMC-FZ70P/OI/vqt5b76/vqt5b76.pdf
Enjoy your camera
tip
Lumix DMC-TZ5 - Adding Time and Date stamp to photos
  • Make sure you have set the date and time correctly on your camera.
  • View the picture you want to Time stamp, by changing left hand slider to green icon.
  • Press the circular 'Menu/Set' button
  • Press down arrow to get to playback mode in the onscreen menu.
  • Press right arrow to access this menu.
  • Press down arrow until 'text stamp' is highlighted.
  • Press right arrow to select.
  • Choose whether to apply stamp to single or multiple photos
  • Press 'Menu/set' to select photo to stamp.
  • Choose which stamps to add. Date, time, age etc..
  • Press 'Menu/set' again and select the 'Yes' box.
The only problem with this is that it will re-size your photos to about 3m, which can make them grainier if you took them at a higher resolution. Unfortunately there is no other way to time stamp your photos on this camera.
2answers
Date stamp required
Use an external photo editor and export photos with visual date stamp derived from exif info within file. FastStone Image Viewer Powerful and Intuitive Photo Viewer Editor and...
How do i get the date stamped on the pictures from my panasonic lumix dmc-fz7
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
How to turn off the photo stamp feature in a Lumix DMC-ZS25
On another panasonic camera, go to the menu in rec mode, and try to find "date stamp". switch it off. (i don't know the right menu of your camera)
Panasonic dmc-tz10 - date stamp
To clarify: Using the Travel date will not show the date stamp on the photo on this camera as it does on other cameras. The date (as mentioned in the most recent post), will only show in the EXIF data.
2answers
I have the time and date set but it does not appear on the picture?
Go into the camera setting and you have to manually select that you want the time and date to appear on photos.
I have a Panasonic Lumix DMC-FX520 and the date stamp wont appear on printed photos. The date shows when I take the photo,how do I get the datestamp to show up afterwards
Normally in the menu settings the options are entered so as to stamp the date in. So open menu settings and check on clock and date settings. check for links to date stamping in the menu and activate.
Sep 24, 2010 • Cameras
Not getting date on downloaded pictures
The date and time (and a lot of other information) is always stored with the picture file in what's called the EXIF data. By default this is not shown on top of the image since neither the camera nor any photo viewing program knows which portion of your photograph is unimportant and can be obscured by this data.
Any photo editing program should be able to show you this data, probably in a separate window. Most photo printing software likewise can print this data, either on top of the picture or in the margins or on the back. Please refer to the documentation for whatever program(s) you're using.
1helpful
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
