I've had to replace my phone 3 times in the past 18 months and got the same model as im on contract. I want to know if anyone has a solution which doesn't involve spending money as i only have it for another 3 weeks. i have to admit i have dropped it a few times but not for a few months now. thanks
SOURCE: I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
SOURCE: Hello, my blackberry curve 8520 has a horizontal
I have the same problem, but it's a vertical white line. I have a BB Curve 8310. From what I've researched on the web, it seems the LCD screen wud have to be replaced.
SOURCE: blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
SOURCE: i dropped my blackberry 8520
Sounds like you have a broken LCD screen. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry 8520 Repair Guide that shows how. Try to look for the Blackberry Javelin repair guide, it is very similar.
SOURCE: how to correct app error 532 for blackberry curve
i have the same problem, what did you do to fix it?
