Engine control cable
Push the end of the new throttle cable onto the linkage on the carburetor. In our C10 example, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
Place the throttle cable clip over the linkage. You may need to pry the end up with a flat-head screwdriver to get it in place.
Secure the throttle cable in the throttle cable bracket located on the intake manifold. This, too, should clip into place.
Route the cable into the cab, being sure to keep it kink-free.
Loop the end onto the end of the accelerator pedal inside of the linkage hole. In other vehicles, there may be a clip on the accelerator pedal that holds the throttle cable in place, which is also easy to do with your bare hands.
Mustang Parts.
Fig. The proper torque sequence for the 2.0L DOHC Zetec engine
