Mower is getting fire and fuel but will not start
My Stanley was running fine and died one day with no luck. I checked everything, well, so I thought. After setting for a year my uncle and I pulled off the gas tank and found the fuse beside the solenoid was bad. Replaced that and boom with a jump off mower fired up and ran until head gasket blew lol.
Its getting fuel to the carb but is the solenoid working on the bottom of the carb they stick and also safety switches go bad and kill the power going to it
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
I hope you find this solution helpful. Please rate it thanks for using Fixya!
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
SOURCE: 19 HP stanley riding mower, wiring diagram
i have a stanley lawnmower 19hp 2003 year where can i purches parts for it need carbs for it.cannot seem to find inything on line.
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
