Error message: this operating system does not meet the minimum requirements, for roxio easy vhs to dvd..... this product will not be installed. Microsoft window xp sp2(64bit) microsoft windows xp sp3(32bit) micrrosfot vista sp1(32?64bit) microsoft windows 7 home premium, professiona, or ultimate(32/64bit)
SOURCE: Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
SOURCE: roxio easy vhs to dvd-out of sync or jerking
Make sure all the connections are connected properly.
SOURCE: get error message unable to load pictures,
download Visual c++ 2008 redistributable package from following link
LINK
install it & restart your pc
SOURCE: Roxio Easy VHS to DVD will not install
Probably your version does not support your OS. Get the lates version from Roxio.
SOURCE: Problem with Roxio Easy VHS
Copy the following into notepad and save it as user.config
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<userSettings>
<Roxio.VHS2DVD.Properties.Settings>
<setting name="EnableUEIP" serializeAs="String">
<value>False</value>
</setting>
<setting name="UEIP_GUID" serializeAs="String">
<value>1beff98f-c0f7-45fd-b1d4-83647eb9e606</value>
</setting>
<setting name="IsFirstLaunch" serializeAs="String">
<value>True</value>
</setting>
<setting name="FirstLaunchDate" serializeAs="String">
<value>30/10/2010 5:16:39 AM</value>
</setting>
<setting name="PlaybackVolume" serializeAs="String">
<value>50</value>
</setting>
</Roxio.VHS2DVD.Properties.Settings>
</userSettings>
</configuration>
Create the following directory(s) in Users-yourusername-Appdata-Local:
Sonic_Solutions\EasyVHS2DVD.exe_Url_hhfgkb1u0ycf2w3tdzo0dhp3nidmxflu\1.0.1.21
Copy the user.config file into the 1.0.1.21 folder and run VHS to DVD - worked for me!
