SOURCE: How to reset the ink level monitor on Canon Prixma MP 160
Disconnect the printer's outlet
Hold the Botton of power while connecting to the outlet
Holding down the power button pressed twice the reset button (red circle with a triangle)
Release the power button
The printer takes about 10 seconds into the show vaor numeroco zero.
Pressing + to the value moves from 0 to 1.
When this value to 1, press the button that is on par with reset, this will light up two lamps
One is that of plain papaer and the other of photo paper, at this point is put paper into the printer
Pressing the power button once or twice (it does not matter), the printer will print a proof sheet
When you print this sheet the value in the display returns to zero, leaving it well
Open scan cover (to remove the cartridges but was not removed), with the lid open faith disconnect the power to printer
Remove the cartridge, close the lid and turn on the printer.
Re-positioned and Refill cartridges in the printer and READY.
SOURCE: canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
SOURCE: canon mp 530 error u043 cant get rid of it
It is registering a empty ink cartridge. If you had the cartridge refilled instea of replacing the cartridge that is what happened. The chip on the cartridge wont register the refilled ink and tells the printer it is empty.
SOURCE: driver soft ware for canon inject printer prixma
You can download the Canon printer drivers from the CANON WEB site. Please click on this link and select the printer model and the XP or Vista printer driver you require :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
