With charger plugged in, battery indicator light lights up on flip cover, screen is blank, phone will not turn on. Just need a new battery or is it the charger?.
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
SOURCE: Blank or White screen on new Motorola Krzr k1 cell phone
found the solution to the white screen! it's the flip sensor.. what you have to do is open the phone hard and fast... make it so when you flip it open, the sensor knows when to turn the screen on and off.. this may take up to 5 or more times.. jus keep opening it hard and it will eventually work!!!
SOURCE: Motorola RAZR V3x Cellular Phone Won't turn on
i have the same phone. it is motorola faulty built of chipsets. just return the phone for a next one
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
SOURCE: Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
