Question about Rolex Datejust Watches
How to remove the back of a rolex watch without the special tool
    Top Expert:
  • Rolex Master
  • 53,765 Answers
Have a jeweler remove it
Posted on Sep 02, 2016
SOURCE:
SOURCE: removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Posted on Apr 11, 2008
SOURCE: ROLEX QUICK-SET FEATURE
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
-Mike
www.perfect-timing.biz
Posted on Aug 12, 2008
escapement
  • 2338 Answers
SOURCE: Cannot put the backing of my casio wrist watch
No, you do NOT need a spec tool. All you have to do is to reassemble watch strap completely(with all the bits and pieces, insl. wings, armour,etc).
Posted on Mar 03, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: Hi. I have a
Hi Susan, most Watches will require a tool to remove the back, some use a knife like tool, and some use an adjustable key type tool to fit the slots of the watch cover, so that you can unscrew the back off. Sometimes you can use a thin knife too, be very careful not to cut yourself, and also not to damage the rubber gasket. The gasket sometimes will need replacement on some watches if they are waterproof. I recommend having a watch expert look at it if you feel you can't do this yourself.
Also the tools are available on eBay. I hope this helps you. Joe
Posted on Mar 14, 2011
Water
You would have to unscrew the back (needs a special tool) and leave it open to dry..then probably have it cleaned. Only a professional watch mender can do this.
BUT Rolex watches are water resistant. It either isnt as Rolex, or you went too deep
Feb 03, 2014 | Rolex Day-Date President 118238 Wristwatch
Howcan I remove the back from my Rolex Daytona What tool doI require I want to remove the back only
its a custom made double handed tool with a milled edge cut out to mesh with the case back to use anything else will mark and damage the watch and to open the back will interfere with its water resistance unless pressure tested again
May 15, 2011 | Rolex Daytona 116520 Wrist Watch
Submariner-how do I open it? I dropped it, and one of the dots(#'s) dislodged on the face.
If it is a true Rolex they require a special wrench that grips the tiny serrations around the base of the back. You will need to take it to a watch repairman, the tool is very costly.
Feb 13, 2011 | Rolex Oyster Perpetual Submariner Date...
How do i open the back of a rolex watch
ROLEX watches can be opened using special case back press and dies. Without those tools there is no way to open ROLEX watch.
Feb 07, 2010 | Rolex Daytona 116520 Wrist Watch
Can;t open back of watchto find date it was made do i need special tool or some thing else can be used
You definitely need special Rolex case back opener. Without it your watch will be locked forever. Rolex cases are so tight, that even when special opener is used, you will need quite strong arms to open it. Rolex case openers sometimes sells on ebay, but they are never cheap.
Jan 07, 2010 | Rolex Daytona 116520 Wrist Watch
Cant open my rolex daytona watch
To open a Rolex watch you need a special Rolex tool to unscrew the case back. They are really on tight and the wrong tool can cause damage. Why mess up a good watch? Once you get in there, what do you hope to do? Change a battery? Nope they don't have one. So please take that fine watch to someone that really knows what to do'
Oct 28, 2009 | Rolex Daytona 116520 Wrist Watch
I can not open the back cover of my Rolex Submariner, I hear something rattling inside.
If the watch is working okay, and it is a self-winding model (i.e. it doesnt not have a battery which relatively few Rolexs do) then the noise you probably can hear is the self-winding mechanism.
Rolex backs are very, very difficult to remove and watch repairers have special tools to do so. As a Rolex is an offically certified chronometer, and therefore has an incrediby accurate and complex mechanism, the backs are deliberatly designed to be difficult to remove by just anybody.
Oct 01, 2009 | Rolex Daytona 116520 Wrist Watch
Taking the glass from my watch
Rolex glasses are held in place by the bezel ( ring surrounding the glass ). Bezel must be lifted off first in case if the glass must be removed. Rolex bezels are friction fitted and are very tight. Usually special tools are used for bezel lifting, but in skilled hands the watchmakers knife can do the job as well (inserting the blade between the bezel and case and slowly prying up all athe way around).
In most cases the bezel still holds the glass when lifted off the case. To release the watch from bezel ring you will need a special press with dies as you will need it for refitting glass and bezel on to the case.
I would advice to find your nearest watch repair shop and ask for help, because without proper tools it is allmost impossible to remove and reset Rolex glasses without damaging them.
Do not forget to rate, please.
Jan 21, 2009 | Rolex Submariner 16618 Wristwatch
Setting the independent hour hand on a Rolex Explorer II
It should be the 3rd position on the crown: 1st date, 2nd hour, 3rd time zone. And don't take it to a "jeler" like jamison said. If you cannot do this watch is fake.
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Faux men's rolex date just
An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
Jan 28, 2008 | Rolex Day-Date President 118239 Wristwatch
Watches Logo
3,699 people viewed this question
Top Rolex Watches Experts
Arturs Kalnins
Arturs Kalnins
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
