your load device problem. some one load device starting load amp high.so find it. check one by one load connect.your load device problem. some one load device starting load amp high.so find it. check one by one load connect.
You can't post conmments that contain an email address.
It appears that you have a bad intermittent connection and those are hard to fix because most of the time, like when you want to work on it, everything is fine! But yes, check the wiring and the switches involved in affected circuits you described.
blocked fuel filter some times a peace of dirt will be to big to pass and block the fuel line for just a second so when u restart it changes the flow and the dirt moves out of the way
This sounds like your alternator maybe going bad. When your alternator starts to go bad lights such as headlights, radio lights will go dim wipers will start to move slower but if you cut one of the things off such as the wipers the lights will get brighter for a few minutes then not long the car will shut completely down. Hope this helps.
