Dear,User Your PC given beep sound for 10 sec.Solution:
1> Check you RAM Slot.
2> Proper Connect RAM Device.
3> CMOS battery connect and check it proper working conduction. if damage change it.
4> Finely if no solved that time all power connector open and reassemble.
Thanks....
Please refer to the beep error codes for your work station here: http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1058075
Usually a 10 second beep is an issue with RAM not detected/installed or an issue with CPU
SOURCE: No signal to monitor / Beeping
Listen to the pattern of beeps, or look at the back of the computer to see the pattern of the diagnostic lights ( 4 lights just under the keyboard/mouse connectors) and check out this site to see what they mean:
Beep Code Meanings
Diagnostic Light Meanings
SOURCE: my dell precision workstation 470 start but don't
Make sure it's plugged in. Or unscrew the case and check the graphics card cables to make sure their plugged in.
SOURCE: My dell precision 470 1st fan is running very fast
Ronwed
Unfortaintly if you have resetted the CPU but still having this issue then most likely the problem is with the CPU. Note you will want to replace the heatsink and fan as well. In addtion info know for sure that you had a thermal event (IE the system majorly over heating) it is possible that the motherboard is damaged as well.
Issken
SOURCE: dell precision 490 led 1 & 4 on
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
SOURCE: I have a broken Dell Precision 470 Workstation.
sounds like a motherboard failure.
Basic troubleshooting, disconnect all external connections except power, see if indications change, if no go remove all expansion cards see if any change, if no go disconnect all drives see if any change. If none, then motherboard.
If at any step you get a change in indications, then see if you can isolate the faulty item
DIAG LED info is here
