Canon ir2520 copy only half page
Its copy half page and printing half page, it new one just installed
    New Friend:
It is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
Posted on Sep 23, 2013
    New Friend:
2520 photocopiers me when I copy the black sheet
Posted on Nov 23, 2015
SOURCE:
  • 23 Answers
SOURCE: Printer stop printing at first half page
reinstall the driver
Posted on Jan 22, 2008
  • 6 Answers
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Posted on Mar 20, 2008
hashchathy
  • 246 Answers
SOURCE: poor print quality - top half page okay, bottom print faded and skips
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Posted on Aug 01, 2008
yooperbud
  • 8637 Answers
SOURCE: half page printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 628 Answers
SOURCE: difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Posted on Apr 22, 2009
How can i fix the the problem with canon ir 4570 which produce an image the half is good and the other is bad . i already change the drum .
Hi. You need to be more specific. Printed paged are OK or it's just when making copies . If both copies and prints are bad . The problem can be in the printer section but if only copies are bad the problem is in the scanning section .
May 20, 2017 | Canon Office Equipment & Supplies
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Canon ir2520 don't print PS files. The PS driver is installed.
Did you buy the option for PS. It may be loaded, but PS is owned by Adobe and you need to buy the rights to use them
Jun 02, 2011 | Canon PCL Printer Kit-AF1 - 2860B001
When using both the FAX and COPY functions of the Canon Laserclass 710 the printed page shows a 2nd "ghosted" image of the primary image about half way down the page. We've tried a few adjustments but the...
Generally, when you have a ghosting problem, the issue is with the fusing unit. If you have a new fusing unit (or if you can get one) install the new unit and the problem should go away.
If you don't have access to a new fuser, you can try replacing the drum/imaging unit. Sometimes a ghosting problem can be caused by a bad cleaning unit (inside the imaging unit), but usually it's the fuser causing the problem.
Aug 31, 2010 | Canon LaserCLASS Fax 710 Printer
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
966 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
