Tensions all should be set at "3" for general sewing if there is no other damage or lint trapped in the tension discs.
Try "flossing" each tensioner with a piece of cloth to remove lint.
If you are still uncertain, try 4 different colours and with all set at 3 to begin, adjust to suit what you see to be loose or tight (small adjustments each time)
If the little one has removed the knobs (they just pull off towards you) and turned the white adjustment wheel beneath, you need to set until happy as above, then put the outer knob back with number 3 in the 12 o'clock position.
Best of...
www.bargainbox.com.au
