Hello I have the PTID 4003TV and it was working fine until one month ago, right after the warranty expired. the radio and the TV works, but the CD player wont read Cds or DVDs. Can anyone please help me?
If you installed this 2 months ago, then you are still under warranty. You need to contact Generac directly before you try to fix yourself and void warranty. Not trying to offend, just being practical.
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
check the owners manual for the stereo and see what file system format you need to use on the flash drive i know i had the same problem when i changed radios worked on my old one but plugged into the new stereo wouldnt load had to unload the music and reformat the flash drive and then reload the music onto it that took care of the problem. where you have tried two different usb drives would say not likely you have bad drives
Ignore the above comment... SD cards and USB play fine on there (i have one). Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
