How to set date and day?
SOURCE: I need instructions on how to set day, date and
These wacthes are made by the Geneva Watch Group. Their web site is http://www.genevawatchgroup.com/
On the right of the screen is a menu, choose "our brands and then scroll down until you find the instructions for your watch.
SOURCE: hello, i bought a keneth
KC are hard ones to find manuals.
Best I can tell you is to call them at 1-800-KEN-COLE.
Best of luck.
Jewel
SOURCE: I just bought a Kenneth Cole Unlisted mens watch.
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
SOURCE: I have a Keneth Cole
Hello
Pull the large pin located in the middle right-hand side (if you're looking at the face) of the watch frame.
Turn the knob to move the mechanical hands on the clock face. Press the pin back into the side of the watch frame when the time is set. Make sure the second hand is moving.
Pull the pin out two places (you should feel two clicks) to set the date. Check to make sure that when you're setting the time, you haven't pulled it out too far. Turn the knob in the "date position" to set the proper date.
Repeat Steps 1 through 3 with the smaller pins on each side of the main pin to set the stopwatch or alternate time zone clocks (if you own a Kenneth Cole watch with these options).
Press the lower left button on the Kenneth Cole digital watches to cycle through the various modes. Press it three times to get into time mode (the face should be blinking). Press the upper right-hand button to change the seconds. Press the lower right-hand button to select the minutes. Press the upper right-hand button again to set the minutes. Press the lower right-hand button once more to get to hours, and then use the upper right-hand button to change them.
THANK YOU FOR VISITING FIXYA
