Sanyo Xacti C6 Camcorder Logo
Posted on Nov 25, 2008
LCD Screen Stays Black
When we power up our Sanyo VPC-C6 the LCD screen stays dark.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
310
Points
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
1helpful
2answers
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
I have laptop by fujitsi it runs normally but the screen is completely black
When the display shows the following cases, that need to be replaced a LCD Inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Laptop black out
When the following situations, you need to replace the LCD inverter:
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Black screen on my digital camera
Sounds like the back light has gone. Probably not worth fixing as it would probably be to expensive because of whats involved in the repair. It's only cheap Sanyo rubbish anyway.
Black lcd screen
I could not find an online manual, but most cameras have an option to shut off the LCD screen when taking pictures. Check this in your manual, there's a great chance this is the problem. If not, you have to seek professional help
When I turn on my new Sanyo VPC S1285 camera it stays on the blue "Sanyo" screen
When I turn my sanyo vpc-s1285 on it stays of the blue Sanyo Screen Can you help me fix this?
Sanyo VPC T700 broken lcd
hi, if you want to buy a replacement lcd screen, pls contact us by email [email protected]. we are direct supplier for camera repair parts, you could get more about us from www.think-tec.com
2answers
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
