2004 chevy 5.3 replaced selector switch on dash will not work have change selector switch and encoder motor on transfer case ,IS THERE a way I can test TCCM
If you had a factory or professional scan tool , check for DTC'S - diagnostic trouble codes . Rather then guessing an replacing parts . What model chevy ? Silverado
Looking up an reading how it's suppose to work , checking code's , view wiring diagrams an checking electrical circuit's with a DVOM - digital volt ohmmeter . An finding out which transfer case it has .
Transfer Case - NVG 149-NP3
Transfer Case - NVG 246-NP8
Transfer Case - NVG 261-NP2
Transfer Case - NVG 263-NP1
The New Venture Gear model NVG 246 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 ft lb of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 40 km/h (25 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, in order to enhance stability.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel. When the ignition key is in the RUN position, the transfer case shift control module monitors the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria has been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module (TCCM) starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position begins flashing to inform the driver that the TCCM has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been engaged. Once the new mode/gear position is fully active, the switch indicator for the new position remains ON constantly. In the event that the TCCM can not or will not complete the shift, the indicator returns to the previously selected position; this is a Transfer Case Shift Control Switch Indicator Flashes, then Returns to Previous Mode condition.
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0359
DTC C0379
DTC C0550
DTC B0790
The neutral indicator circuit consists of an ignition 3 voltage circuit and a neutral indicator control circuit. When the neutral mode has been selected by the driver, current is supplied to the neutral indicator by the ignition 3 voltage circuit, traveling through the neutral indicator LED at which time the transfer case shift control module supplies the ground through the neutral indicator control circuit. This DTC detects an open, short to ground or a short to voltage.
DTC B2725
ircuit Description
The range/mode switch circuit consists of 4 modes. The transfer case shift control module supplies 5 volts to the switch through the 5 volt reference circuit. The current travel through the resistor of the currently active mode. The current is then returned to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit.
When each of the modes are selected they complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch input to determine whether the Neutral, 2HI, 4HI, or 4LO mode was selected by the driver.
A lot involved in these 4X4 systems , Your best bet ,take it to a qualified repair shop. You obviously have no idea on how this works , code setting capability ,how to test electrical circuits etc...
I think it has 722-6 Transmission, according to the owners manual I follow the steps. Gear leaver must be neutral position, engine must be idling, just press low rang button. I did all the instructions, but didn't engage the low range. If you need more details please ask specify.
