HP Officejet Pro L7780 All-In-One InkJet Printer Logo
Posted on Nov 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Streaks though the pages
I get voids in the color through the ever page every time. what can I clean or take abart. Printer is 6 months old. Office jet pro 7780. I can change the resolution and it gets better but somethng is wrong.
Anonymous
Level 2:
Scholar:
  • Expert 174 Answers
  • Posted on Nov 25, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
174
Questions
0
Helped
48673
Points
461
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
you will have to check the Minolta web tech support team for this one.
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
k24674
Grand Canyon Tech
Grand Canyon Tech
