Changed new hard disk then tried to install Windows 7 but the laptop cannot boot from anything I tried. Tried to restore on defaults in Bios but still failed. From Bios, can detect Hard Disk, CD/DVD Drive, even USB drive to boot. But still the error message appear.
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
Thank you for your reply but unfortunately I tried that with DVD and USB as first boot device but still no changes. But still cannot detect anything and still give me the no bootable device - insert boot disk and press any key.
This means you have a motherboard/BIOS problem.
This may work.
Try reseating the hard drive and then see if the Acer will boot up with the hard disk.
SOURCE: well got same problem as above when try to boot an
This error means that the hard drive is either not connected properly or has failed. To fix it check and make sure the hard drive is connected properly and tight. If it is unfortunately that means the hard drive needs to be replaced.
SOURCE: I made a liveusb linux and then restart the
You must set BIOS to boot from Removable USB Drive, first.
**should be USB not USD
I tried with DVD and USB as first boot device but still no changes. But still cannot detect anything and still give me the no bootable device - insert boot disk and press any key
