My blackberry is perfectly fine it works well too, but for some reason it comes to a blank white screen and stops working, however when i put it on charge it automatically reboots and works perfectly fine again. It usually turns into a white screen when my battery bar goes low. e.g full charge and 1 bar drops it will happen.
SOURCE: I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
SOURCE: Blackberry Bold cannot charge and screen goes blank
1. You could have an OS problem or hardware issues.
Simplest first to troubleshoot the OS, by loading a newer, updated OS release.
http://www.blackberryforums.com/general-9000-series-discussion-bold/188088-latest-os-9000-4-6-0-451-4-6-0-266-multilanguage.html
2. If you can live without performing a backup of your device you can follow these steps to correct the issue:
1. Download the latest Vodafone UK firmware using this LINK (4.6.0.282)
2. Install the firmware onto your PC running BlackBerry Desktop Manager
3. Go to c:\Program Files\Common Files\Research In Motion\Apploader and delete the vendor.xml file.
4. Connect your device and open Desktop Manager
5. When prompted select "Upgrade Now" (If you are not prompted select Applications Loader > Update > If your device isn't detected remove the battery and connect the device > once the update starts insert the battery again).
6. Follow the prompts and your device will be upgraded.
SOURCE: My phone is stuck in a constant reboot cycle where
go to service center and get your phone software updated .
SOURCE: blackberry curve 3g 9300 worked fine then for no
Hello, 1) Here is how you back up your device. 2) Here is how you reload the software cleanly on the device. 3) Here is how you restore your data to the device if it is not backed up automatically.
I would attempt to pull the battery from the phone first. Wait about 1 minute or so then put it back in. This is hard reboot. It may take some time to come back up.
If that does not work you may need to backup and reinstall your OS.
If all else fails, you should contact your mobile carrier especially since its only a few months old.
I hope this helps
