Just finished shampooing, and now vacuum wont power up anymore.
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
SOURCE: how to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
SOURCE: dont know how to put the shampoo system together on my kirby g6..
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
SOURCE: Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
SOURCE: need a cheaper alternative shampoo for kirby
Look up your local janitoral supply companies in the yellow pages. Encapsulation shampoo should be readily available in AU.
Here is a list of websites to check out:
http://www.enterprisesearch.com.au/search-engine-subcategory/subcategory/Cleaning%20Products/
This one in particular may have what you need if you call them: (on line shopping not available yet "coming soon")
http://www.nationwidecleaningsupplies.com.au/
Nationwide Cleaning Supplies - Milperra Store
Phone: 02 9774 2000
Testimonial: "tHANK YOU. I will try that. I can't beleive that shampoo is so hard to find. thanks for your trouble."
