I cant seem to be able to hook my rt2390 system up to my new philips tv there is no sound coming out of the speakers when i turn the system on I tried hooking it up with the red and white cables but I guess Im doing something wrong or putting the cables in the wrong place please help! :)
Https://www.manualslib.com/manual/361231/Rca-Rt2390.html
Here for the manual.
SOURCE: hooking up speakers
I'm sure you hooked it up the correct way,This rt2250 is a problem to almost everyone.I have two of them and they both present all types of faults
SOURCE: Only VCR2 sound working, no video
if you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
SOURCE: I bought a refurbished RCA
You have some choices. I'm assuming you are using Input 1 and 2 for the component, composite, S-video connection options that are stacked: input 2 above input 1 and input 3 to the left of input 1.
1) You can always home theater system speakers in use for the DVD player and cable box. In that case, disconnect the audio cables from the TV for both devices and connect them to the audio inputs of the Home Theater system. Leave the video cable in place. (If you use component video and separate audio cables, this will be easier than if you use a composite video cable. You would probably need extra audio cables.) The TV speakers will not work in this configuration unless you use another input (for exampe: TV OTA or PC that isn't connected to the home theater system). .
2) You can leave the current connections alone and connect the TV's audio out to one of the Home Theater system's audio inputs. The audio out is towards the bottom of the back panel between the VGA PC video in and the PC audio in. Once connected, turn on the TV and turn off the TV speaker. Menu > Setup > TV Speakers (On/Off) (navigate with the up/down and left/right arrows as needed). If you want to control the sound of the Home Theater system (and it is compatible with your system) set the next line Audio Out to Vari. Otherwise leave it at Fixed (and control the volume with the Home Theater systems controls). Also turn on the Home Theater system and set it to the desired input.
In all cases, you need at least one RCA audio cable with two plugs (red/white). Maximum of three for the component video with video from the cable box and DVD player to TV and then out to the home theater center. See the TV manual for configuring a connection to an external amplifier.
If you have no sound and the TV speakers are off, try new cables, make sure you are set to the correct input, and make sure that the connections are secured correctly. (Make sure you didn't accidently connect to a Audio In on the TV for example since the audio in for the PC is on the far side of the audio out relative to the VGA port.) Make sure the Mute is not enabled on any device. Make sure everything has power and that no headphones are connected to anything. If you have noise when the TV is on, then try moving the home theater system farther from the TV and/or using shielded cables. Check if the unit can receive an AM or FM signal (the tuner is built in but you will need an antenna) or the audio when directly connected to a device.
If it doesn't work with any connection, it probably needs service. The unit came with a one-year warranty when new, max of 90 days refurbished. Check your documentation.
I hope this helps.
SOURCE: Im tryin to hook up
Assuming (since you don't identify them) your RCA has at least one available analog stereo input and your TV has a analog stero-only output, just connect them with RCA cables, set the TV's output volume (if it has menu item for it) to FIXED so theTV volume doesn't affect the output, select the input on the HTS and you're good to go.
Another way might be to take the TV-related audio from the cable box straight to the HTS in whatever manner is the best quality. Digital would make mulitchannel audio possible.
Or name the devices involved, find the manuals and read up on your applicable options.
SOURCE: Just bought the RCA1023 and
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor. Try rotating the power cord in the wall outlet. If it still does it with no cables or anything external attached it
