I would like to wall mount my Protron 32 tv but I don't know where to mount the flat mount. Can you tell me where?
Thanks
Most mounts are pretty expensive from retailers i purchased mine from the internet it was a hell lot cheaper. Try www.bracketsrus.co.uk very cheap and will deliver next day.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Thanks!!!
