I have some experience in appliance repair, however I haven't worked in the field in over fifteen years, technology has changed dramatically since then. My dishwasher is malfunctioning in the way, that both drawers are showing a solid red light and constant double beep. Another customer seems to have the same problem and the solution was to replace the water sensor...Does this seem correct, if so where do I locate the water sensor,,,,Thank you
SOURCE: Model KUDD01DPPA KitchenAid dishwasher Error:
Hi.
You can find parts and diagrams for this model here.
Alternatively here: KUDD01DPPA0.
About the problem, the inlet valve and hose is single, therefore the valve is working.
Check the inlet hose setting. Check pressure from lines.
Check the fill hose for the upper drawer. That is likely causing the problem.Check the fill hose in the link assembly, and the valve Check in drain (Fill hose for upper drawer is 4 here).
Regards.
Ginko.
Please check this bellow links to troubleshoot your problem:-
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#itcleanspoorly
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
