Hi, I am looking for a manual in English for a wimsew 737 Overlocker as I cannot understand how to thread my overlocker as it is written in extrememly bad english and makes no sense,
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
SOURCE: JanomeLock JL 603 Overlocker Manual
Not sure if this will help, but try--- www.2instructions.com
SOURCE: user manual brother overlocker 925d english
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
SOURCE: Janome mylock 744D overlocker
Have you tried youtube for 'how to' videos? I just found this one that might help. Good luck. http://www.youtube.com/watch?v=JyrAhSQAEeY
SOURCE: how do i thread a janome overlocker
there's a good you tube video and threading an overlocker
