Solution: 1) Check the indoor/outdoor connecting wire in proper point. 2) Change the connection of electric wiring, if reversed phase. 3) Check the protection device, if malfunction, replace it. 4) Measure the resistance of the outdoor coil thermistor. If the resistance is normal, replace the outdoor controller board Thanks.
P8-Abnormality in outdoor unit. 1) Wrong wiring of indoor/outdoor connecting wire 2) Reversed phase 3) Protection device is working 4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire. 2) Change the connection of electric wiring. 3) Check the protection device. 4) Measure the resistance of the outdoor coil thermistor. If the resistance is normal, replace the outdoor controller board.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
I am not familiar with a P8 code nor do I understand where you are seeing this But, go to mrslim.com and look under Customer resources, Library and then input your model number. Select Technical & Services. Product Catagory is Mr. Slim Ductless, Sub Catagory is M-series Multi Split, Current models. Remember you have inside units and one outside unit. You will need to look at each model number to find information on both. Usually Mitsubishi's will have two lights that will blink in patterns to indicate what could be wrong. The P8 code is new for this Diamond Dealer!
