Need installation instructions
SOURCE: I need an instruction manual
Thank you for posting your question here on Fixya.com.
I believe this is the correct one. If not, select the correct version from those found on Jandy's site here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: Instruction/Owners manual for a Leisure Rangemaster 55 Auto
I have the just moved to a house with this same oven. I can't find the exact manual online, but the timer/clock seem to work the same as this one..
http://www.leisurecp.co.uk/upl/15858-GR6CV.pdf
SOURCE: Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you. I guess this site won't want us to post email.
The Canister is very easy to use, just DO NOT remove the metal tension seal ring. To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing.
Note: use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture. My 800-gallon "green" pond clears up in 7-days.
M
SOURCE: trying to install Flotec Dual Voltage pool pump.
The motor should have a diagram on it showing where line 1 & 2 go. It does not matter which of your two line wire goes to which post, as long as you put one wire per post and have the motor set for the correct incoming voltage, you'll be fine.
SOURCE: Lost owners manual need to reprogram the light
have you been to www.aerogarden.com. they have a troubleshooting area for the reprogramming of the lights.
