See this possible causes:
Vent
obstruction see for any
Heating element
test for defective., see how to test
Internal ductwork
get clogged, clean
Cycling thermostat
defective will be break the heat or stop, replace see how.
God bless you
SOURCE: I just bought and installed
you should have 4 wires / red, white, black and green / red and black goes to the outside temmals and white to middle and green to cabinet / check and see if you have it connected that way / larry
SOURCE: Frigidaire Affinity dryer (8months old) dries
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If your dryer is not drying like it once did or if you just have not
taken the time to give yourself a clean dryer in a long time then you
need to do that. At least once a year the dryer cleaning should take
place. Lint build up in the dryer duct is one of the main causes
for your dryer to fail.
Here is the rest of this tip about Dryer
Maintenance
heatman101
SOURCE: Frigidaire Affinity dryer not drying,
See this link and then see part number F36 for the thermal fuse location and description - verify your model number:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150159&diagram_id=1239258#d1239258
SOURCE: I have a Frigidaire Affinity Clothes dryer
Hi wonderfullym...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me thumbs up
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
